Activity › Forums › Apple Final Cut Pro Legacy › Color Correction and exposure changes from AE to FCP 7
  • Color Correction and exposure changes from AE to FCP 7
    Posted by Gabriel Valda on April 5, 2012 at 12:32 am
    I did the color correction in AE 5 and then brought it back to FCP and the exposure changes,
    its a gamma thing, but cant figure out how to fix this without redoing the color correwction, howe to make FCP interpret the right gamma ? also in FCP when some footage is in still (stoped) i looks darker , when i hit play it gets lighter (only while playing ) … getting really confused , please help !!
    Thank you
    Michael Gissing replied 14 years, 5 months ago 3 Members · 5 Replies
  • Michael Gissing
    April 5, 2012 at 1:46 am
    What codec did you export the grade from AE as? Does your FCP sequence match that codec exactly? Did you need to render?
    Gamma problems can be due to RGB versus YUV. If AE can export ProRes 422 there shouldn’t be a problem.
  • Gabriel Valda
    April 5, 2012 at 6:41 pm
    Yes I exported Prorez HQ from AE , color changes in FCP a bit, cant find an option fro fcp to interpret footage as 2.2 gamma…
  • Jeff Meyer
    April 6, 2012 at 1:35 am
    Select the problem clip(s) and and press butterfly-9 to call up the Item Properties. From there you can force the gamma interpretation you want.
  • Gabriel Valda
    April 6, 2012 at 3:42 am
    thak you, i did try that before , please help , how can i change the gamma ? says gamma level but no options to change it!, on pics and other media (diferent format ) it says (source) and i can type 2.2. there, but all the footage does not have that option, i does not say source and no otion to type gamma level in… …
    Thank you
  • Michael Gissing
    April 9, 2012 at 11:19 pm
    Is the gamma changing on an external monitor? Depending on how you are monitoring both AE and FCP the difference may be just the computer monitors. You can’t trust computer displays within software to be accurate.
