Activity Forums Apple Final Cut Pro Legacy Color Correction and Bit Depth
  • Color Correction and Bit Depth
    Posted by Kent Kajino on June 29, 2006 at 9:56 pm
    Is precision in color correction independent of bit depth?
    I read a post from a couple of months back stating that only the color space should be considered.
    So, if I had HDCAM 8-bit material blown up to uncompressed, there is no point going to 10-bits instead of 8-bits, as long as I’m in 4:2:2 color space? Is this true? Or does bit depth make a difference in simple and small color correction at all?
    My RAID is doing 350MB/s, so I perfer to stick with 8-bits rather than approaching the limit by going 10-bits.
    Michael Gissing replied 20 years, 2 months ago 2 Members · 1 Reply
  • Michael Gissing
    June 29, 2006 at 10:19 pm
    350MB/s is plenty for 10 bit. Bit depth affects grey scale resolution so if you are adjusting white/ black or gamma levels, then bit depth matters.
