Activity › Forums › Avid Media Composer › Color correction
  • Color correction
    Posted by Editproblems on September 24, 2006 at 10:50 pm
    When I am doing color correction is there a way to only color correct one layer of the image. I have the main footage then title bar overtop of it but when i start the color correction process it changes the color of my title bar and i dont want that.
    I need help badly!!
    Michael Hancock replied 20 years ago 4 Members · 6 Replies
  • Editproblems
    September 24, 2006 at 10:52 pm
    hahaha ok nevermind i figured it out….
  • Annaël Beauchemin
    September 25, 2006 at 10:11 pm
    what solution have you found?
    did you find a way to CC a clip on top of another without having to step in?
  • Michael Hancock
    September 26, 2006 at 1:45 am
    The original poster said that their color correction was changing the color of their title and the underlying video–I’m assuming they only wanted to change the color of their video.
    If that’s the case, they probably (originally) applied their color correction to a filler track above both, which would in turn affect both. To do only the video clip they had to apply their color correction to the video clip only–which I assume they did, since they figured it out.
    Mike.
  • Annaël Beauchemin
    September 26, 2006 at 5:53 am
    as odd as it may seem, applying a color correction effect on a clip above another results in both clips being affected by the color correction.
    For example, if you add a 3d warp the the top layer, crop it and then add a CC, It seems that the CC doesn’t get the new “mask” created by the 3d warp and applies the CC as if it were an effect on the filler. It makes CC a bit hard when you work with picture-in-pictures.
    This is on MCA and symphony… not sure about Xpress.
  • Geraint Pari huws
    September 26, 2006 at 12:49 pm
    step in to the clip!
    apply cc at the lowest level
  • Michael Hancock
    September 26, 2006 at 1:32 pm
    Avid effects work top-down, and if an effect is not the only effect on a clip or is not a nested effect it affects all the layers below it. If you’re familiar with After Effects, it’s kind of like each layer can act as an adustment layer–great sometimes, and royal pain in the neck other times.
    As far as color correcting a clip, Amheus is right, though, just step into your effect and apply your CC effect (oddly enough, double clicking it in segment mode to expand the track won’t allow you to add a CC effect–it gives an error message–you have to step in for a CC effect).
    Mike.
