Activity Forums VEGAS Pro Color correction
  • Color correction
    Posted by Brian Killeen on June 5, 2013 at 3:12 am
    Hy guys
    Is there any way to create a filter or plug in in sony vegas , I want to color correct several clips at the same time with the same effect .
    Brian Killeen replied 13 years, 3 months ago 3 Members · 3 Replies
  • Michael Acres
    June 5, 2013 at 4:13 am
    Get one scene where you want it then give it a name(replace where it says Default toward the top) and then save it by clicking the save icon to the right. you now have a saved preset you can apply to any scene
  • Graham Bernard
    June 5, 2013 at 8:07 am
    There are several places we can apply FXs:
    * Directly to an Event on the Timeline – The result of this is that FX is restricted to that Event.
    * In the Project Media to the Media – The result of this is that any time that FX-ed Media is dragged to the Timeline the Event will have that FX
    * At the Track Header – This results in ALL the Events on that Track being affected.
    * Through the Preview Window – This results in ALL the project getting the FX.
    * Copy > Paste Event Attributes – This is a quick and easy way of copying an FX and it’s attributes from one Event to another Event. But be warned, ANY Event adjustments will be pasted to the Target Event from the Source Event. Second warning is that now in VP12 the Source will wipe-out any existing Target attributes and be replaced with the Sources atribs.
    Cheers
    Grazie
  • Brian Killeen
    June 5, 2013 at 10:49 am
    Wow
    Thanks for the great advice and tips guys this really helps me out here.
    Sheers.
