Activity Forums Apple Final Cut Pro Legacy Color Correction
  • Color Correction
    Posted by Carlton Hathcoat on February 24, 2009 at 5:24 pm
    We are editing a video that was shot at several golf courses in Wales. We have some beautiful day shots, and some cloudy day shots. I am looking for the easiest way to make some nice color correction that will boost the blue in the sky and the ocean, make the green fairways look vibrant, as well as in some cases make the sky warmer (give it that early morning look. We have a small budget and quick turnaround (can’t spend a lot of time on the color correction), so if there’s any software anyone can recommend, or an easy way in FCP to do this please explain. We do have Boris BCC5. I have not used motion. Thanks!
    Hector Berrebi replied 17 years, 5 months ago 4 Members · 4 Replies
  • Walter Biscardi
    February 24, 2009 at 5:31 pm
    All of this is very easily done in Color which is included with Studio 2. We have some tutorials here on the Cow and also a 2 hour introductory DVD to Color for sale here on the Cow as well to get you started in the app.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Carlton Hathcoat
    February 24, 2009 at 10:48 pm
    thank you, I will likely buy that DVD. Do you have a simple recommendation for a filter that gives the video an over all soft glow, I call it the Cybil Shepherd glow from Moonlighting, basically giving it a look as if it were shot with a pro mist white filter?
  • Jason Diebler
    March 13, 2009 at 8:38 pm
    You can get that trick with some compositing.
    Double-up your video layers on V1 & V2. Use a “guassian” blur or “glow” on V1. Right-click and play around with your composite modes on V2 (screen/overlay perphaps). You may have to futz with your opacity levels on 1 or 2.
    This will give you a wholly different stylized look, just be careful not to overdo it.
  • Hector Berrebi
    March 14, 2009 at 8:11 am
    Cybil Shepherd glow… 🙂 another way to achieve it
    basic color correct your video,
    then
    double up your video, from V1 to V2
    on V2, put a desaturate filter and a gaussian blur at 8 to 25%.
    now lower the opacity of V2, 30% would be a good start, then go up until you are happy with the result.
    you can also change the amount of blur on V2, the amount of desaturation and how open the hilights CC 3 way on V2 are. all these will change the look of your glow
    about matching sky from cloudy to sunny. this is never simple. the sun affects every single shadow in your shot in a way that only the sun (or BIG expensive lighting) can. when its cloudy, not just color and temp change, but the entire shadow scheme of the shot, and while the first 2 can be fixed, the later is rarely the case.
    there are several techniques for sky replacement (look up in google). some involve keying out the sky and colorizing it with color wheels and saturation (secondary color correction). others mask out the sky and replace it with a new one. in other cases its a combination of the two techniques, masks (vignettes) to isolate then key to select.
    if shot is moving. you will need tracking.
    color can do a pretty good job at all of that.
    if you have complex trees on your skyline, the first method would probably work better, as trees can be hard and time consuming to mask.
    here are two basic tutorials. none using FCP but you will get the idea.
    https://library.creativecow.net/articles/kramer_andrew/sky_replacement.php
    https://www.viddler.com/explore/Emeek77/videos/135/
    if you are not sure of what you are doing, and can’t bring in someone who can fix it for you.
    maybe re-edit to use a minimal amount of bad sky shots? (the viewers never really know what you didn’t use) or maybe exaggerate the difference between the two looks instead of trying to match them.
    hope this helps.
    Hector Berrebi
    Schibber Group
    prePost Consulting
