Activity › Forums › Apple Final Cut Pro Legacy › color correction
  • color correction
    Posted by Suzin Daly on September 25, 2008 at 10:06 pm
    shot with 2 camera – , broadcast and SD standard (panasonic 100) where used to for a feauture film. Suggestions on how we can pull it together for continuity ……………..
    Arnie Schlissel replied 18 years ago 7 Members · 11 Replies
  • 11 Replies
  • Walter Biscardi
    September 25, 2008 at 10:55 pm
    Easy to do in Color.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Shane Ross
    September 25, 2008 at 11:13 pm
    To be blunt, hire a professional colorist. What kind of “tips” were you expecting on a forum? Color is an art. Can’t be explained in a forum.
    Shane
  • Shane Ross
    Shane
  • Arnie Schlissel
    September 26, 2008 at 12:21 am
    [walter biscardi] “Easy to do in Color.”
    Easy for a “colorist” to do in Color! Not so easy if someone has never used Color, or has no experience or training as a colorist!
    Honestly, if you’re really looking to color grade a feature for broadcast or theatrical output, you would be best off taking it to a post house or lab that is properly equipped & staffed for this. There’s a lot of technical & aesthetic know-how, which is impossible to impart in a couple of forum postings. And you need monitors & scopes that are properly calibrated to match your final output.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Walter Biscardi
    September 26, 2008 at 12:52 am
    [Arnie Schlissel] “Easy for a “colorist” to do in Color! Not so easy if someone has never used Color, or has no experience or training as a colorist! “
    I’m not a colorist by training, I’ve just learned how to color grade using the 3 Way CC and then Final Touch / Color and what is being asked in this thread is very easy to do in Color. Matching two cameras is incredibly easy in Color using the Still Store and saved Grades.
    Read my Blog!
  • Ben Holmes
    September 26, 2008 at 1:23 am
    [suzin daly] “where used to for a feauture film”
    Really? A feature film? I would suggest employing a colourist before theatrical release…..
    Uh.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • Arnie Schlissel
    September 26, 2008 at 1:29 am
    Walter, if I recall, you had a colorist come in to train you on Final Touch. Plus your other experience as an editor doing broadcast work. I’d count that for something.
    Arnie
  • Walter Biscardi
    September 26, 2008 at 2:32 am
    [Arnie Schlissel] “Walter, if I recall, you had a colorist come in to train you on Final Touch. Plus your other experience as an editor doing broadcast work. I’d count that for something.”
    Correct, Bob Sliga taught me and then I put pretty much everything he taught me onto my training DVD. He did not teach me color grading, he taught me the interface and gave me some ideas on what I could do to make my coloring better.
    Bob is now working for Apple as part of the Color team.
    Read my Blog!
  • Jason Porthouse
    September 26, 2008 at 8:52 am
    Suzin,
    Please don’t take this as a flame, it’s not meant to be – but this is the sort of post that really gets my wick. Kinda like me going on a motoring forum and saying ‘I want a car. Tell me what to get…’
    We need a bit more info. You need to do a bit more homework! A cursory read of the FCP manual would give you options to consider – using the 3-way CC, basic workflows etc. Have you thought about the problem? Have you considered your options? If so, what specific issues are you facing?
    We’re all busy professionals here. I’m happy to help, as will many others, but you need to meet halfway.
    Jason
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
  • Rennie Klymyk
    September 27, 2008 at 7:02 pm
    Like others have indicated this may not be the best project to start with color. However Apple has made the tools affordable so like anything else, the more you do with it the better you will get.
    Color perception is something that can be learned I believe. I came from a photography background and learned to print my own prints. After a year or so of regular printing I found myself tweeking 1.5 cc’s of cyan out and adding 3cc’s of magenta to a negative to get that perfect color. I realized how sensitive I had become to observing color. I think we are able to hone this sensitivity with lots of practice.
    All editors should be using proper evaluation grade monitors with stable consistent output and should have a controlled lighting environment to be working in.
    It would also be helpful to take a color blindness test before you get too far with it. Color blindness effects about 9% of males and .4% of females. Some simple tests are here:
    https://en.wikipedia.org/wiki/Color_blindness
    “thou can not stir a flower without crumbling a star” ……Henry Wadsworth Longfellow
