Activity Forums Adobe After Effects color correction
  • color correction
    Posted by Criis Daw on July 25, 2006 at 11:02 am
    Yo Cows
    Any body got any time saving tips on color correction. I have a stop frame animation and there are descrepencies in the white balance between frames so the white changes from blue tones to yellow, as do the greens. Any body know a quick way to smooth this out ?? . I suppose i could match every still in Photoshop but it will be rather time consuming and i want to get this out the door by end of play today….
    Thanks in advance
    love you
    Chris
    Criis Daw replied 20 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Barend Onneweer
    July 25, 2006 at 12:41 pm
    There’s a color stabilizer in AE… you might want to check that first.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Criis Daw
    July 25, 2006 at 12:50 pm
    Thanks for the response..
    I had a go with that but i got very unpredicable results. Maybe there is a trick to using it but it made things worse not better
    Cheers
    Cris
  • Justin Productions
    July 25, 2006 at 3:35 pm
    Effects > Adjust > Curves always worked well for me.
    Good luck.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • Criis Daw
    July 25, 2006 at 4:03 pm
    yes i am sure but each frame has a different white balance … I have hoping to avoid a frame by frame approach.. Can curves solve this problem ????
    I don’t see how but i would love it if it can ??
    thanks
  • Dorel Iordache
    July 25, 2006 at 9:29 pm
    I was trying to solve a similar problem where I had large white point and tonal range discrepancies with small DV footage clips. Because I only had 5 or 6 shots to match, I ended up matching individual levels values by hand using the following procedure. Probably it doesn
  • Filip Vandueren
    July 26, 2006 at 10:39 am
    It mght just be faster to do the frames in one by one in photoshop using adjustment layers: you can just sample the same grey or white every time by one click, using the eye-droppers in the levels or curves window.
    A shame After effects doesn’t offer that.
  • Criis Daw
    July 26, 2006 at 7:30 pm
    Thanks for the advice guys..
    looks like either way i got my work cut out.
    The flicker is good i agree but the changing shadows and and light through the trees do a fine job of this with out the shots chaging hue..
    Anyway through chalenges we learn i guess
