Activity Forums Apple Final Cut Pro Legacy Color Correcting Uncompressed HD – 8 Bit vs. Float
  • Color Correcting Uncompressed HD – 8 Bit vs. Float
    Posted by Script-to-film on June 25, 2007 at 3:48 pm
    1) Can someone explain why going to Color or Shake for grading in 32-bit float is better than 8-bit?
    2) What’s if it’s just for a DVD. Does 32 make that much of a difference for a SD DVD?
    3) If you were submitting a indy narrative drama film to major film festivals, what route would you go? 32-bit or just FCP 8-bit filter? Thanks.
    Gary Adcock replied 19 years, 2 months ago 2 Members · 2 Replies
  • Script-to-film
    June 25, 2007 at 3:51 pm
    Just to clarify, we’re talking about Uncompressed HD (originated as HDV, but converted to HD 10 bit uncompressed).
  • Gary Adcock
    June 25, 2007 at 4:16 pm
    [Script-to-film] “Can someone explain why going to Color or Shake for grading in 32-bit float is better than 8-bit?”
    8bit is 256 levels of gray per color channel
    for your purposes all in-camera recording is at 8bit
    10bit is 1024 levels of gray per channel
    12bit is 4096 levels of gray per channel
    14 bit is 16384 levels of gray per channel
    16 bit is 65536 levels of gray per channel (about the total# of colors in CMYK per channel)
    “What’s if it’s just for a DVD. Does 32 make that much of a difference for a SD DVD?”
    More colors = better color, smoother gradients and composites but harder to compress.
    10bit is more than enough depth for your HD or SD content.
    your HDV starts as 8bit 4.2.0 color on the tape
    IMHO it is not uncompressed after an HDV capture, it is DE-compressed.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
