Activity › Forums › Apple Final Cut Pro Legacy › color correcting on iMac?
Posted by Jason O’hara on May 23, 2013 at 12:50 amI am doing color correction on an iMac, is this a bad idea?
Nicholaus Mtawa replied 12 years, 11 months ago 3 Members · 10 Replies -
Shane Ross
May 23, 2013 at 12:53 am -
Shane Ross
May 23, 2013 at 4:49 amThen you need to get a Thunderbolt out device…Blackmagic UltraStudio Mini Monitor is $145…connect that to a decent HDTV…and you should be good to go.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Nicholaus Mtawa
October 26, 2013 at 8:06 am -
Shane Ross
October 26, 2013 at 6:08 pm -
Nicholaus Mtawa
October 26, 2013 at 7:05 pmNo, it has firewire port, Display Port and USB Ports
Nicholaus Mtawa
Shane Ross
October 26, 2013 at 11:12 pmThen no, alas. BlackMagic Decklink has USB portion, but none of them are for the Mac, PC only. And FireWire options are no longer made.
Shane
Little Frog Post
Nicholaus Mtawa
October 27, 2013 at 7:44 am…..and then, what should i do and i want to do coloring on my videos like professional. Any suggestion sir!!
Shane Ross
October 27, 2013 at 5:32 pmBuy a computer with Thunderbolt, then get something like the AJA T-TAP or Decklink Extreme Mini Monitor…and a good HDTV.
Shane
Little Frog Post
Nicholaus Mtawa
October 28, 2013 at 10:15 amThank you shane, hoping to work on that. if anything wrong i’ll get back to you for help!
Regards,
Nicholaus Mtawa
