Activity › Forums › Apple Final Cut Pro Legacy › color correcting multiangle
  • color correcting multiangle
    Posted by Mccaincow on September 6, 2005 at 6:57 pm
    Is is possible to color correct one angle after footage has been edited within a multiangle? In other words the footage is all cut up and I would have to select each clip to color correct, if I cant find a way to color corect the entire angle.
    David Bogie replied 21 years ago 2 Members · 1 Reply
  • David Bogie
    September 7, 2005 at 3:58 pm
    Go back to the original clip and apply your color correction before, upstream, of the multi-angle sequence.
    Not sure why this is giving you trouble.
    bogiesan
