Activity Forums Apple Final Cut Pro Legacy Color Correcting HD Converted to SD
  • Color Correcting HD Converted to SD
    Posted by Soreyrith Um on November 3, 2007 at 1:55 pm
    How do you guys color correct HD footage that is destined for SD delivery? The footage is edited in an HD timeline.
    Do you color correct the HD timeline on an HD monitor, then convert to SD for delivery? Or do you nest the footage in an SD timeline and CC on an SD monitor? Does FCP (or AJA Kona) take care of the color space conversion from Rec. 709 HD to Rec. 601 SD?
    http://www.HotSpotsOnline.com
    David Roth weiss replied 18 years, 10 months ago 4 Members · 6 Replies
  • David Roth weiss
    November 3, 2007 at 2:50 pm
    [sumfun] “Do you color correct the HD timeline on an HD monitor, then convert to SD for delivery? Or do you nest the footage in an SD timeline and CC on an SD monitor?”
    If you were delivering a project on VHS that was mastered on Digibeta would you color correct on VHS? Of course not…
    Just do your best color correction job in the HD domain. Maybe you’ll want to make some minor overall corrections to the SD down convert, such boosting chroma, but otherwise there’s not reason to worry.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Walter Biscardi
    November 3, 2007 at 3:40 pm
    [David Roth Weiss] “Maybe you’ll want to make some minor overall corrections to the SD down convert, such boosting chroma, but otherwise there’s not reason to worry.”
    Actually, I find it the other way around. I have to pull back on the saturation and chroma for SD, especially reds. HD is much more forgiving with saturated colors.
    Depending on the format of SD you’re delivering to, you may have to lift the blacks to make the show legal in SD.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • David Roth weiss
    November 3, 2007 at 3:53 pm
    I wasn’t actually trying to be specific, just giving an example, and a bad one at that…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Soreyrith Um
    November 3, 2007 at 6:22 pm
    Thanks guys. The reason I asked was that I was seeing what Walter mentioned. The colors looked good in HD, but when I output to SD it looked a little too saturated. I thought maybe this was due to the difference in color spaces between HD and SD.
    So I guess what you’re recommending is to CC in the original format, then make any adjustments in the delivery format. I usually try to avoid doing things twice, but if that’s what it takes, then I’ll do it. The second time is more an overall adjustment, so it shouldn’t take long.
  • Chris Poisson
    November 5, 2007 at 2:30 pm
    My workflow is a tiny bit different, but FWIW, I put my HD material in an SD sequence, and just do CC once. I have been pleased with the results as have my clients.
    Have a wonderful day.
  • David Roth weiss
    November 5, 2007 at 4:09 pm
    Chris,
    I think this is entirely based on the set of assumptions you’re working with for archiving projects originated from HD sources. If you want to keep an HD master as your final archived master, you should color correct as HD. If you’re abandoning HD altogether for SD, then color correct an SD version.
    My workflow is based on the assumumption that I am always going to archive a final HD master, so that I can maximize my options for the future. So, I do everything I can in HD, and make conversions to SD only when all work is completed. If minor CC is needed that’s no problem.
    David Roth Weiss
    Director/Editor
    Los Angeles
