Activity › Forums › Adobe After Effects › Color correcting all but ears?
Posted by Johnny Smith on December 19, 2010 at 10:42 amLet’s say I want to apply a color correction effect to everything but her ears.
How do I do that?Johnny Smith replied 15 years, 9 months ago 3 Members · 7 Replies -
Graham Macfarlane
December 19, 2010 at 11:53 amYou need to use masks:
Duplicate your footage layer and on the top most duplicate, use the pen tool twice to mask out the ears (set both masks to subtractive)Place your colour correction on that masked layer!
Graham Macfarlane
3D animator and VFX specialist
London UK -
Johnny Smith
December 19, 2010 at 1:16 pmmakes sense, except for the: “use the pen tool twice”.
I’ll try to figure it out, thanks. -
Todd Kopriva
December 20, 2010 at 12:55 amHere’s a video tutorial in which I color-correct just a face. You could use the same approach, just targeting a different area.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Graham Macfarlane
December 20, 2010 at 8:22 amBecause the ears are two separate features you need two separate masks to define them hence use the pen tool twice.
Todds tutorial is great though because if your actors face is moving it will save you a lot of time. Also, masking the face with one modified ellipse which avoids the ears is probably a little quicker and will be easier to work with, with the tracking data than if you had two separate ear masks.Graham Macfarlane
London UK -
Todd Kopriva
December 20, 2010 at 4:01 pmNote that you can use any mask or combination of masks on the solid-color layer used in the technique that I show. I just used an elliptical mask because it was a) adequate for the scenario of selective color correction in the tutorial and b) it was a fast and easy way to demonstrate the principle in a short tutorial.
