Activity Forums Apple Final Cut Pro Legacy Color Correcting Advice on FCP 5.1.4
  • Color Correcting Advice on FCP 5.1.4
    Posted by Patrick Jones on July 22, 2009 at 7:40 pm
    Need to be taught how to wish on this one. I got some 11am-1pm shots that I think look good- except the face – I tried a plugin called FaceLight, but did not do any good. Anyone have any suggestions on how I can make these shot work instead of going and doing a re-shoot? Thanks for your schooling!
    Also snapshots of what you do would rock!
    FCS 1 – MBP 2.93ghz 4gb RAM, 300gb 7200 Internal HDD, iStarUSA Dual Dock with (10) 1TB 3.5 Seagate Barracuda drives, and a couple 250’s Maxtors, and Seagates.
    Michael Gissing replied 17 years, 2 months ago 4 Members · 9 Replies
  • 9 Replies
  • Shane Ross
    July 22, 2009 at 8:00 pm
    Well, if you had examples to show us, that would be something. But 11AM to 1PM…not much light change there…
    Shane
  • Patrick Jones
    July 22, 2009 at 8:07 pm
    I uploaded but I guess it did not post?
    Let me try attaching again
  • Tom Matthies
    July 22, 2009 at 9:26 pm
    As noted in a similar post a few days ago, you night try Lyric Shadow/Highlight filter. It’s a free plugin. I’ve used it numerous times and it works pretty well. Try Googling it.
    Tom
    Life moves pretty fast. If you don’t stop and look around once in a while, you could miss it.–Ferris Bueller
  • Patrick Jones
    July 22, 2009 at 9:42 pm
    Do you guys see the Frames I posted? I cant see them when I view this entire thread. Also d-loading the free plugin now.
  • Shane Ross
    July 22, 2009 at 10:24 pm
    Like Sgt. Schultz…”I see nothing….NOTHING!”
    Shane
  • Patrick Jones
    July 22, 2009 at 10:28 pm
    Im new – and I know they are moderating my threads, but I post the links when Attaching –
    Let me Attach again!
    Above is the Embed version and below is the link version
  • Shane Ross
    July 22, 2009 at 10:39 pm
    OK..those I see.
    Now…what’s wrong? The shadows switching sides of the face? Well, that is due to the direction your talent is facing. Nothing major there. It would be nice if you had a bounce card on set to fill in the dark side, but …whatever. COLOR allows you to isolate the face and add more fill. As does Colorista. And you can layer shots, use the garbage mattes and the 3-way…
    Shane
  • Patrick Jones
    July 22, 2009 at 10:44 pm
    I’m still on Final Cut Studio 1 – Final Cut Pro 5.1.4 – So no Color program option. NOW that said. The free plugin mentioned above worked fine. It’s just applied to the entire shot and would not let me matte of a certain spot – ie, the face. oh well – And I still get the green check mark, so that is good –
  • Michael Gissing
    July 22, 2009 at 10:48 pm
    Lyric shadow highlight followed by facelight, plus watch the Limit effect 3 Way CC tutorial that Richard Harrington did here at the COW (search is your friend).
    I have rescued worse with a combination of all these plugins and techniques.
