Activity Forums Adobe Premiere Pro Color correcting a single camera angle within a multicam sequence
  • Color correcting a single camera angle within a multicam sequence
    Posted by David Gaudio on February 26, 2013 at 5:14 am
    Can anyone direct me to a link/tutorial on how to apply a color correction filter (or any other, for that matter) to a single camera within a multiclip sequence? I don’t quite see how to do it – can the multicam be broken down into individual shots later on somehow (and the filter applied that way)? Thanks in advance for any help.
    Patrick Finnegan replied 10 years, 5 months ago 7 Members · 14 Replies
  • 14 Replies
  • Angelo Lorenzo
    February 26, 2013 at 5:50 am
    A multicam is a nested sequence. If you cut it already then you can either 1) apply the effect to each clip individually or select all the blocks, nest it again, and then apply the effect to the new single nested sequence. You shouldn’t see any performance penalties from nesting.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • David Gaudio
    February 26, 2013 at 6:14 am
    Thanks – I was hoping not to have to apply the filter to every edit individually – just wanted to know if there was a way to apply a filter to a single camera within a multicam, but globally on a timeline rather than edit by edit.
  • Angelo Lorenzo
    February 26, 2013 at 7:59 am
    If you have CS6, there is also the option of adjustment layers if you want to avoid nesting.
    Angelo Lorenzo
  • Jon Barrie
    February 26, 2013 at 1:09 pm
    G’day David,
    There is a way to do exactly what you want.
    Drilling into the Multicam edit you can find the camera angle (represented by the track number) add the effect to the clip/s in there and go back to your Multi-camera edit to see the nest update 🙂
    To get into the MC Sequence right click it from the Project Panel and select “Open in Timeline”.
    You should see the full stack of clips that make up the MC workflow. Hide the eyes of the video tracks above the camera angle you need to adjust. When done treating it as you would with any clip, turn the eyes back on.
    Every time you cut to that camera angle the fix will be seen. 🙂
    You can stack timelines as broken out panels so you have the MC Edit on one and the MC (Nest) Sequence on another.
    Check this clip on how to do that. https://www.youtube.com/watch?v=1qcJVlq9bcs&feature=share&list=UUJFdvHfcVBpErDSkAX3PLmg 🙂
    Cheers JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • David Gaudio
    February 26, 2013 at 6:20 pm
    Fabulous – thanks so much, Jon!
  • Aravind Balasubramanya
    February 19, 2014 at 10:31 am
    Awesome…. This was exactly what I was searching for….
  • Patrick Finnegan
    December 8, 2015 at 6:16 pm
    I know this is a very old thread but there are new options available so I thought I’d update the answer.
    Premiere Pro CC has the ability to do all cuts/subclips in a multicam sequence at once. Just right-click on the sequence and choose “flatten” from the Multicamera options. Next, click on the cut you want to change and press “F” for Match Frame. The Source clip will now open in a source monitor. Apply the effect / filter to the source and it will be applied to all the cuts from that same source file.
  • Jordi Robert
    December 14, 2015 at 11:07 am
    Hi patrick
    Thank you for your post.
    I have a question. Once the sequence is flatten and effects applied to clips, can I continue editing using multicamera in that sequence?
    or
    Is there a way to colour correct one camera before doing the multicamera edit?
    Thank you
    Check out my Vimeo page https://vimeo.com/user9949700/videos
  • Trig Simon
    January 4, 2016 at 9:31 pm
    Hi Patrick,
    You look like you are up to date on color correcting multicam in Premiere Pro CC 2015. Can you help me here:
    When I make a change to one camera as I am cutting, that change, be it scale, color, or probably others too, seem to go onto the next camera.
    So I have to get rid of the effect in order to go on. How can I stop this from happening.
    Thank,
    Trig
    Trig Simon
    Video Images by Trig
    832 Main
    Toledo OH 43605
    419-693-0872
    http://www.videoimagesbytrig.com
  • Patrick Finnegan
    March 18, 2016 at 11:11 pm
    Hi Trig,
    Sorry for the delay, I’ve been on some high demand projects for a couple of months and I failed to respond to a number of similar requests. Did you resolve this issue or do you still need help?
    Pat
