Activity › Forums › Adobe After Effects › Color controller overide
  • Color controller overide
    Posted by Davor Kampel on February 13, 2016 at 6:53 pm
    Hi all! I set up a color controller where I control all my colors, but I have a problem. For example, I want all the elements that were blue, and connected to the same color controller, to stay blue, except for one element. I tried changing the color directly on that element but it doesn’t work that way, and the solution can’t involve disconnecting that element from the controller. So I need a way to override the color controller. Any suggestions?
    Cheers!
    Kalleheikki Kannisto replied 10 years, 7 months ago 3 Members · 2 Replies
  • Chris Wright
    February 13, 2016 at 7:00 pm
    can you put a control on the controller and keyframe it?
  • Kalleheikki Kannisto
    February 14, 2016 at 9:52 am
    If you are using the Fill effect for the color, you could add a checkbox control and link the effect opacity to it (under “Compositing options” of the effect).
