Activity › Forums › Apple Final Cut Pro Legacy › Color completely changes with Export
  • Color completely changes with Export
    Posted by Sam Fuller on February 3, 2010 at 10:21 pm
    I shot in extremely low light with a Panasonic HVX. When Color Correcting in FCP, I can adjust the levels to the point where i can see everything clearly – despite a lot of grain. However when I export this sequence, without changing any setting, the quicktime uncompressed (and compressed) image comes out completely milky and washed out. The final export looks completely different than how the image appears in FCP. Any advice?
    Thank you.
    Isaac Viejo replied 16 years, 6 months ago 4 Members · 3 Replies
  • Samuel Hall
    February 3, 2010 at 11:26 pm
    Are you playing this exported file in QuickTime?
    If so, it sounds like a problem with the gamma settings of your exported file. Or, more accurately, a problem with how QuckTime is displaying it.
    Try opening QuickTime preferences and check the box at the bottom of the ‘General’ tab called “Enable Final Cut Studio color compatibility.” That is, if that is not already so.
    Samuel Hall
    DP/Editor/VFX/Music
    http://www.vimeo.com/samhall
  • Arnie Schlissel
    February 4, 2010 at 3:11 am
    How does it look on your calibrated broadcast monitor? What do your video scopes say? If it’s “milky” it sounds like you’ve lifted your blacks. You need to keep some blacks at 0 IRE while lifting the mids.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Isaac Viejo
    March 7, 2010 at 5:17 pm
    Same problem working on a DVCpro HD 720p50 project.
    I already checked the “Enable Final Cut Studio color compatibility” in QT 7 but the problem persist in QT X and TV…
    the only codec that show same colors in QT X is Animation but when I check in QT 7 the picture is darker.
    Any idea….??
    thanks…
