Activity Forums Adobe After Effects Color clamping when rendering
  • Color clamping when rendering
    Posted by Shadow Caster on March 12, 2019 at 10:31 pm
    Hey All,
    I’m working in After Effects with a raw EXR sequence in 32 bit color depth. The color space is set to ‘none.’ When I render the frames that I have worked on (a simple patch and some clone stamping, added noise and used match grain as well as gaussian blur) the colors are clamped–they are flat and not what I’m seeing in my composition viewer.
    What could be causing this? Are some of the effects I used not ok for 32 bit depth? If so, is there any workaround to achieve those effects?
    Thank you in advance!!
    Michael Szalapski replied 7 years, 5 months ago 2 Members · 2 Replies
  • Shadow Caster
    March 13, 2019 at 1:17 am
    One more note…..I’ve been messing with the export settings a bit and now my patches/effects are bright but the rest of the plate is very dull. it inverted somehow…… Cannot figure out this mystery! 🙂
  • Michael Szalapski
    March 13, 2019 at 3:03 pm
    Without knowing what your render settings are, it’s really hard for anyone to give much in the way of an answer.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
