Activity › Forums › Adobe Premiere Pro › Color Changing in Premiere Pro Export
Posted by Andrew Drachman on May 10, 2014 at 7:32 pmI’ve noticed that the color in the export from my sequence looks different from what I am seeing in the program source window in Premiere. I tried both Quicktime and h264 formats and got the same result.
Is this a setting within Premiere that I need to change in order for my program window to accurately reflect what will be seen in the export?
I am using a late 2013 iMac with NVIDIA GeForce GTX 780M 4096 MB graphics card.
Thank you to anyone that can help!
Andrew Drachman
https://www.AnimusStudios.comAndrew Drachman replied 11 years, 10 months ago 3 Members · 7 Replies -
Tim Kolb
May 10, 2014 at 10:42 pmUse a non-QuickTime format and look at it outside of QT player…the gamma error resides there.
(as it has for more than a decade unfortunately)
TimK,
Director, Consultant
Kolb Productions,Adobe Certified Instructor
Andrew Drachman
May 12, 2014 at 2:21 amAre you saying the exported file should be something other than a Quicktime format?
If you look at the image in the original post, you can tell the color difference between what is being shown in the export window and what’s in the program source monitor. That seems to be happening in Premiere Pro, not the export.
Tim Kolb
May 12, 2014 at 2:42 amIt’s gamma? Mid range skewing a bit high for a milky sort of look?
TimK,
Andrew Drachman
May 12, 2014 at 1:47 pmYou’re going to have to forgive me Tim, I’m not entirely sure what you are asking in regards to “gamma”.
I am just receiving a more saturated image in my program source monitor than in my export window and, therefore, in my exported file.
Tim Kolb
May 12, 2014 at 2:44 pmYes…what your eye sees as saturation difference is likely the midtones ending up a bit brighter. QuickTime has had this issue for a very long time. H264 files in particular, don’t map properly.
If you export to an H264 file (not a mov H264 or MP4), and then play the file in VLC player, you’ll notice that the file looks right…play the same file in QuickTime and you’ll see the difference.
If you encode to a QT wrapped H264 file (a .mov), or if you just play an H264/MP4 file in QT player, the grayscale curve (the “gamma” curve) is interpreted incorrectly.
TimK,
Dustin Parsons
May 12, 2014 at 7:43 pmUnfortunately, it’s Apple software that does it. I ran into a similar problem https://forums.creativecow.net/thread/335/66624
Andrew Drachman
October 15, 2014 at 1:07 amHi Tim,
Do you have a solution as to how to get the intended color in an exported file? I kinda gave up on fixing the issue at the time I wrote this post, but 5 months later and I’m still experiencing the same problem.
I exported samples (MPEG2, h264, QT h264, QT ProRes and just an exported JPG from the program monitor) from Premiere and took screen shots of them open in QT player next to the corresponding preview. There is a clearly noticeable difference between the two images.
Exported Frame from Program Monitor:
I’ll be the first admit that I’m not an expert when it comes to codecs or exporting, so I won’t be surprised if there is a simple fix to this. I’m hoping there is!
