Activity Forums Apple Final Cut Pro Legacy Color changes when exporting a sequence
  • Color changes when exporting a sequence
    Posted by Johnnie Travis on April 1, 2005 at 10:52 pm
    I’m trying to “nest” a sequence that has a video clip that’s duplicated two times and layered on top of itself (3 clips total). I’ve applied a few effects to the two top layers and added two different composite modes to the two top layers. I want to export the layered sequence as a clip, bring it back into FCP, and then apply color correction. Here’s my problem: When I view the three composited layers in the original sequence, and it’s rendered, it looks fine. After I export the sequence as a Quicktime movie and bring it back in, the colors are different. I’ve tried exporting the sequence as both a 10 bit Uncompressed movie, and Animation – best. Both clips have the same problem. Any ideas?
    G5 DUAL 2.0, 4GB RAM, AJA I/o, 10.3.8, FCP 4.5 HD.
    Johnnie Travis replied 21 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
