Activity Forums Adobe Premiere Pro Color changes not displayed in program monitor
  • Color changes not displayed in program monitor
    Posted by Levan Birkadze on December 17, 2016 at 12:43 pm
    Hey guys,
    When changing colors on video clip on a timeline, program monitor does not preview the changes, however if I tweak colors on a master clip (with Lumetri) source monitor does. Also, when I click export media, preview window is showing the changes. Program monitor seems to be the only one not displaying changes.
    p.s. I tried others effects like fast blur, and its working. Colors (fast color corrector, Lumetri) are not working.
    what can be the problem?
    Min Lee replied 7 years, 4 months ago 6 Members · 10 Replies
  • 10 Replies
  • Samuel Brown
    December 18, 2016 at 9:22 am
    are you using adjustment layer on your timeline than add color correction onto the layer
  • Levan Birkadze
    December 19, 2016 at 9:54 am
    No, I was applying colors without an adjustment layer, however now I tried with adj layer and it didn’t work either 🙁
  • Levan Birkadze
    December 19, 2016 at 11:33 am
    more info:
    In picture below, I tweaked the colors but there is no effect on a program monitor however,
    On picture below, I opened Media Export and can see the changes
    COMPUTER INFO:
    OS: Windows 10 Pro
    Processor: Intel Core i5 760 @2.80GHz
    Installed memory: 16.0 GB
    System type: 64-bit Operating System, x64-based processor
    Graphics Card: GeForce GT440
    PROJECT INFO
    Premiere Version: 2017.0.01
    Footage: Full HD .mov H264 files from T3i
    FAILED FIX ATTEMPTS
    Reinstalled Premiere
    Tried on other clips with different formats
    Tried on other projects
    Tried adjustment layers
    Cleaned Media Cache Database
  • Tero Ahlfors
    December 19, 2016 at 12:26 pm
    Try turning the mercury playback engine to software only.
  • Levan Birkadze
    December 19, 2016 at 12:36 pm
    WOW, I did change it to software only and strange thing happened:
    It only shows changes when I am grabbing and dragging the Lumetri sliders (saturation,contrast, exposure), however when I release it, it changes are not displayed
  • Levan Birkadze
    December 19, 2016 at 2:23 pm
    Tero,
    I think it happens, because the previews are deleted when you change to Sofware only.
    look in the picture below, when I make a change to colors, red color bar appears on the top of a clip meaning that this segment of the sequence does not have a rendered preview file associated with it.
    So when i I render within the timeline, changes are visible.
    am really confused.
    p.s. I updated my video drivers
  • Joseph Siracky
    May 1, 2017 at 6:47 pm
    Levan,
    Did you by any chance resolve this issue? I started experiencing the exact same thing two days ago, and updating my OS and Premiere have not changed anything.
    Best,
    Joseph
  • Min Lee
    April 7, 2019 at 10:37 pm
    This looks like an old thread but figured I’d answer it since I ran into the problem today and it’s 2019. The global effects toggle switch needs to be turned off/on. One way to do it is to add the “fx” button to the program monitor shortcuts. Click on the “+” on the bottom right of the program monitor, then drag the “fx” button to the toolbar. Once it’s there you click it on/off to see/hide the effects. That’s it!
  • Jonas Dickson
    May 2, 2019 at 6:06 pm
    This just happened to me as well (May 2019). Your answer saved me a lot of frustration and taught me about a valuable function! Thank you!!
  • Min Lee
    May 3, 2019 at 4:53 pm
    No problem!
