Activity Forums Adobe After Effects color change when exporting from after effects to swf file
  • color change when exporting from after effects to swf file
    Posted by Rahjee Muhammad on June 10, 2009 at 1:55 pm
    I created a short animation for a website I am doing. I am new to after effects but when I preview the movie in after effects it is great. But when I export it and preview, there is a pick hue when the letters fade in. I have preserved rgb and done everyting I know to do. And hints?
    Rahjee
    Mitch Lewis replied 14 years, 5 months ago 4 Members · 3 Replies
  • Simon Bonner
    June 11, 2009 at 1:22 am
    Hi Rahjee,
    Sounds like a compression issue. Try rendering with the compression set to low (or quality to high) and see if you still get the same issue.
    Simon Bonner
    youtube.com/simonsaysfx
  • Todd Kopriva
    June 11, 2009 at 12:00 pm
    Are you using color management? If so, one thing to be aware of is that colors will be converted to sRGB on output when you create a SWF file from After Effects. I don’t know if this explains your issue, since I can’t see what you’re seeing, but it is the one “gotcha” that I know of with regard to colors output to SWF.
    There’s a whole section on getting consistent color when exporting to SWF in the “Color management workflow in After Effects CS4” paper.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Mitch Lewis
    April 25, 2012 at 3:16 am
    I had the same problem today. It ended up being that a blending mode was being used – Color Overlay. I was able to solve the problem by pre-composing the comp and then exporting to SWF. Poof! Problem solved.
    Sony EX3, Canon 5DM2, Sachtler tripod – 20+ years as a videographer/editor
    Experienced with Apple products, Final Cut Studio, Adobe Creative Suite, MOTU Digital Performer, Flip4Mac, etc…
