Activity Forums Adobe After Effects Expressions color change to blinking cursor expression
  • color change to blinking cursor expression
    Posted by Robert Paynter on August 19, 2014 at 8:09 pm
    I’m using this expression to animate a blinking cursor.
    I would like to change the color and size of the cursor. Is this possible?
    CH = Math.round(effect("LetterNumber")("Slider"));
    BlinkSpd = effect("BlinkSpeed")("Slider");
    F = Math.round((time * BlinkSpd) % 1); //result flickers between 0 and 1 for blinker on-off;
    TypeSpd = effect("LetterNumber")("Slider").speed;
    if (F==1 | TypeSpd > 0){Cursor = "|"} else {Cursor = "";}
    substr(0,CH) + Cursor;
    Robert Paynter replied 12 years ago 2 Members · 3 Replies
  • Dan Ebberts
    August 19, 2014 at 9:21 pm
    You could add an animator for fill color and scale (set to what you want for the cursor), add an expression selector (delete the range selector), and set the expression selector’s amount expression to something like this:
    CH = Math.round(effect(“LetterNumber”)(“Slider”));
    if (textIndex < CH+1) 0 else 100
    Dan
  • Robert Paynter
    August 20, 2014 at 2:47 pm
    Thanks Dan. That worked Perfectly.
  • Robert Paynter
    September 16, 2014 at 6:55 pm
    I have an issue with this expression. When Justified Right, the line bounces back and forth with the blinking of the cursor. I understand why but is there any simple fix for it ? I added a space between the ” ” but that of course is not perfect.
    if (F==1 | TypeSpd > 0){Cursor = "|"} else {Cursor = " ";}
