Color change from outside programs to after effects 2019
When I import files from Illustrator into after effects, the colors shift to a lighter, more pale version. The color codes are the same in both programs, but look completely different. I also will come up with color schemes from the website https://coolors.co/. When I copy the color code and paste it into the color picker in after effects, it shows me a much lighter, more pale version there as well. My illustrator files are in RGB.
When I am in after effects and create shapes from vector layer, the colors dramatically change to a lighter, less contrasted color. I’m attaching images of the before and after of when I do this. I cannot figure out what is going on.
