Activity Forums Adobe After Effects Expressions Color change driven by JSON-file
  • Color change driven by JSON-file
    Posted by Sebastian Martinez on May 12, 2020 at 10:14 pm
    Dear Expression wizzards,
    I’m trying to achive this
    https://www.youtube.com/watch?v=JPiyOGyjWvI
    but not with the hight of the shape layer but with its fill.
    There is a JSON-file imported into my project. In there sections for individual counties (for example “[0]”) with several days (“day0” to “day45”) and corresponding values (lets say 50 to 2000).
    In my comp is also a Null-Object wich has two Color Control effects to provide two different colors. One is for a low value, the other fo a high value.
    Over time I’d like to fade between these colors according to the values in my data.
    I alredy tried but I’m stuck with this (and I haven’t magage to complete it):
    c = footage("tripcountsPerCountyPerDate.json").sourceData; // data-source imported in project
    v1 = c[0].day0; // first value of "0"
    v2 = c[0].day45; // last value of "0"
    startcolor = thisComp.layer("Null 42").effect("Color 1")("Color");
    endcolor = thisComp.layer("Null 42").effect("Color 2")("Color");
    ease(time, 1, 29, startcolor, endcolor);
    linear(v,0,100,startcolor,endcolor);
    So is it linear or ease at the end? And how do I get the values to drive the color?
    Thank you so much and best wishes
    Sebastian
    Sebastian Martinez
    CGI-Designer
    Cologne, Germany
    AE, AI, PS, 3ds max, C4d
    Sebastian Martinez replied 6 years, 3 months ago 2 Members · 3 Replies
  • Sebastian Martinez
    May 13, 2020 at 3:33 pm
    Hi folks,
    I gave it another try myself and with the help of a friend of mine who is a Javascript-Pro, though he hasn’t ever touch AE before:
    counties = footage("test.json").sourceData;
    minmax = counties[counties.length-1];
    countyName = name.split("-")[1].split(" ")[0];
    var result;
    for(var i = 0; i < counties.length-1; i++) {
    if(counties[i].ID === countyName){
    result = counties[i].days;
    //v = result[timeToFrames(0)];
    v = result[Math.round(thisComp.layer("Null 42").effect("Slider Control")("Slider"))];
    linear (v,minmax.min,minmax.max,startcolor,endcolor);
    Data-source is a JSON-file imported into AE. The layer name ist a reference to pick its specific values out from the JSON. The part in the middle I don’t understand. But the results are driven by an animated slider (from 0 to 45 wich are the separat values animated over time). And the two colors for having a transition between them come from Color Controle effects named Color 1 and Color 2.
    The JSON-file partly look like this:
    The code works well. But might be written better I guess…
    Sebastian Martinez
    CGI-Designer
    Cologne, Germany
  • Tomas Bumbulevičius
    May 16, 2020 at 2:30 pm
    Hey Sebastian, any chance to actually know more about the colors?
    Lets say its blue for low, and red for high values. Does interpolation above works without introducing any non-related color values? Since color is 4 dimensional array – I wonder what results such interpolation brings in real life scenarios ! Cheers!
    Find out more:
    Motion Graphics Design & After Effects Tutorials
    On YT
    On VH
    May 26, 2020 at 1:37 pm
    Hi Tomas,
    thanks for asking! Regarding the colors – it just simply works. Even with 3 colors, two for max and min value and the third for medium value. The more colors you use the more distinguished is the result.
    For that I finally changed the workflow a bit by just using black and white for min and max values, prerender the result and on that image-sequence I used the Colorama-Effect to ramp values with multible colors. That way it is easier to edit the desired colors.
    Sebastian Martinez
    CGI-Designer
    Cologne, Germany
