Activity Forums Adobe Photoshop Color change b/w photoshop and fcp
  • Color change b/w photoshop and fcp
    Posted by Alex Markman on March 21, 2013 at 4:45 pm
    I’m bringing in a specific pantone into fcp from photoshop, but the color is being altered slightly when i bring it in. i’ve tried importing as a png, photoshop file, etc. I’ve never had this problem before.
    Working in RGB color space in photoshop. Any help would be appreciated.
    alex m.
    Jeff Hinkle replied 13 years, 5 months ago 2 Members · 1 Reply
  • Jeff Hinkle
    March 21, 2013 at 6:27 pm
    FCP (like every NLE) doesn’t honor ICC or ColorSync color profiles. Although both it and Photoshop are RGB space, they’ll display differently because Photoshop uses a calibrated monitor profile to adjust colors on-screen and FCP won’t. You might be able to get a closer look if you assign the Apple RGB color profile to your image and then import that into FCP.
    But with FCP, what’s more important than what you see on your screen is what you see in your scopes and on a calibrated broadcast monitor. And accept the fact that most people watching at home will never see the same color you do…
    It is easier to destroy than to create.
    More fun, too.
