Activity › Forums › Adobe After Effects › color banding
color banding
Posted by Pentepug on March 7, 2006 at 4:52 pmDoes anyone know any solutions dealing with color banding? We’re getting heavy banding when using 3d lights on a color solid.
Thanks!Adolfo Rozenfeld replied 20 years, 5 months ago 5 Members · 5 Replies -
Steve Roberts
March 7, 2006 at 5:13 pmUsually we add a bit of noise and/or work in 16-bit. Try searching the COW for “banding”.
Greg Quitiquit
March 7, 2006 at 6:01 pm[Steve Roberts] “Usually we add a bit of noise”
Years ago there was actually a simple recipe posted here (or was it over at the old WWUG?) But anyway it involved adding noise as Steve suggests, and some Gaussian Blur. Paradoxically, I’ve noticed that .2 or .3 Gaussian Blur actually makes some images appear sharper in the final video rendering (on an analog monitor, at least.)
It shouldn’t take you too much experimentation to come up with a formula that works for you.
Greg Quitiquit
Vince Becquiot
March 7, 2006 at 7:46 pm“Heavy” banding would also occur if you rendered in an open GL setting instead of advanced 3D.
Vince
Vince Becquiot
March 7, 2006 at 7:49 pmAlso on a side note, color banding seems to be much more visible on some LCD monitors.
Vince
Adolfo Rozenfeld
March 8, 2006 at 7:01 amSome time ago I had the opportunity to use the “Deband” effect, included in one of the Tinderbox plug-in sets. Pretty amazing. Especially designed to remove banding without adding so much noise. I don’t remember which specific Tinderbox set (there are a couple) it was in, since I don’t own it myself.
Of course, a project with 16/32 bit processing, and rendered to a 10 or 16 bit codec should exhibit no banding at all, with no need for a compromise solution.
Hope this helps.Adolfo Rozenfeld
Buenos Aires – Argentina
https://www.adolforozenfeld.com
adolfo@adolforozenfeld.com
