Activity Forums VEGAS Pro Color Banding while decoding MJPEG
  • Color Banding while decoding MJPEG
    Posted by Carlos Zapater on February 24, 2013 at 2:39 pm
    Hi!
    I have some issue that is driving me nuts. It is the first time I use this workflow with Vegas and I don’t seem able to solve it.
    I’m capturing my screen with a software called Dxtory using the mjpeg codec Picvideo v4. The resulting video is crisp, clear and with very good quality viewed with Media Player HomeCinema.
    Then when it comes to import it into Vegas begins the nightmare. The preview window shows a low quality picture due to a heavy color banding. First I thought that it was only the preview but the final video showed the color banding as well (Mainconcept AVC). I tried tweaking the bitrate, changing preview quality and switching to 32bit pixel format. Nothing changed in preview and in final video.
    Then I remembered that Vegas uses the obsolete VFW framework and thought that maybe it was using its own mjpeg codec to decode the video into the editor so I was limited by the quality of such decoder.
    I don’t know if that’s the reason but in case, I tried activating mjpeg in ffdshow VFW configuration for mjpeg format with no results. I didn’t think that PicVideo also comes in VFW format and it didn’t work either. Seems that even with VFW you are stuck with Sony decoders.
    Now I am in a dead end. Any ideas to solve that issue will be very appreciated.
    Martz Grant replied 13 years, 2 months ago 3 Members · 31 Replies
  • 31 Replies
  • John Rofrano
    February 25, 2013 at 12:23 am
    [Carlos Zapater] “I’m capturing my screen with a software called Dxtory using the mjpeg codec Picvideo v4. …Then when it comes to import it into Vegas begins the nightmare. The preview window shows a low quality picture due to a heavy color banding.”
    You should try the Morgan Multimedia M-JPEG codec. It works great the Vegas Pro and produces excellent quality.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Carlos Zapater
    February 25, 2013 at 7:44 pm
    Hi John. Thanks for answering.
    I tried installing the demo version and still have the same problem. Do you know if Vegas uses his own decoder for editing?
  • John Rofrano
    February 26, 2013 at 12:04 am
    [Carlos Zapater] “I tried installing the demo version and still have the same problem. Do you know if Vegas uses his own decoder for editing?”
    Something is not right with your computer then. Before I answered your post I installed the demo or Morgan on a new Windows 7 + Vegas Pro 12.0 virtual machine and I rendered some of my HD footage to M-JPEG and then imported it back into Vegas Pro and it looked exactly like the original. This should work.
    Do you have any codec-paks installed like K-Lite? They could be messing up your system. If so, uninstall them.
    ~jr
  • Carlos Zapater
    February 26, 2013 at 4:16 pm
    [John Rofrano] “Do you have any codec-paks installed like K-Lite? They could be messing up your system. If so, uninstall them.”
    Uh, no! I always avoid such packs and only install the codec I need.
    I have tested the footage in another pc with vegas and it looks great in time line. I’m running out of ideas…
  • John Rofrano
    February 27, 2013 at 12:29 pm
    [Carlos Zapater] “I have tested the footage in another pc with vegas and it looks great in time line. I’m running out of ideas…”
    Yea, that’s what I’m seeing too. When you right-click on the event in Vegas and go to the Media tab, what does Vegas say for the video format? Is it using the Sony MJPEG or PicVideo MJPEG? Then do the same on the PC that it looks good on. Is that different?
    ~jr
  • Carlos Zapater
    February 27, 2013 at 6:28 pm
    Uh… it gets weirder.
    I rendered the clip in the pc 2 (the “clean” one) and I saw some jaggy edges in all the frame. I searched google and ended in a creativecow post of somebody with same problem (and answered by you 🙂 ) It seems related with using blackmagic 32 bits codec to capture and Vegas 64 bits to edit. I searched for blackmagic 64 bits codec in its web with no success. But anyway the picture didn’t have color banding and the media tab said “Blackmagic MJPEG codec” (obvious).
    I still haven’t gone back to home and check pc 1 (the “dirty” one) but I guess it will say PicVideo in media tab as in pc 2 didn’t say Sony MJPEG. Let’s see…
    If Vegas is using PicVideo (the original codec) then I guess the color banding will be due to bad development of VFW version or simply there’s no 64 bits VFW version… It is a shame.
    I will post when I arrive.
  • John Rofrano
    February 27, 2013 at 7:14 pm
    [Carlos Zapater] “If Vegas is using PicVideo (the original codec) then I guess the color banding will be due to bad development of VFW version or simply there’s no 64 bits VFW version… It is a shame.”
    If you temporarily uninstall PicVideo then Vegas Pro should use the Sony MJPEG decoder. If that looks OK, it may be a PicVideo problem.
    ~jr
  • Carlos Zapater
    February 27, 2013 at 8:53 pm
    Okey.
    After more tests here are my points
    – Opened project in vegas. Click at event and the media tab says PicVideo MJPEG 64 bits VFW codec.
    – Unistalled PicVideo. Cannot open clips in Vegas. Says there is a problem with codec.
    – Installed Morgan trial. Project opened without problems. Media tab says it is using Morgan codec. Rendering confirms Color banding is gone but now the picture appears like jagged or with loose of resolution.
    – Checked all options regarding to fields order. All of them set to progressive (which is correct)
    – Tried playing rendered file in various players, activating and deactivating internal and external filters. All with same jagged picture (so, defect comes out from vegas ‘as is’).
    – Tried rendering in various formats and codecs from Vegas. Still jagged.
    – Tried loading clip in Premiere (here never had color banding) and rendering an .mp4 Still jagged!!
    Conclusions:
    – Color banding is a PicVideo issue. No probs with Morgan.
    – Jagged picture is maybe a limitation of the Morgan trial? In its web they don’t explain trial limitations and seems that usage is only limited by time. I was almost happy we have almost solved the mistery of color banding and then this appears.
    I tried to contact through morgan website form asking about this new issue.
  • John Rofrano
    February 28, 2013 at 12:36 am
    That’s really strange because I rendered some HD footage with the Morgan MJPEG codec trial and it looked great. No jagged edges or anything. I was using the 64-bit version of the Morgan codec.
    ~jr
  • Carlos Zapater
    February 28, 2013 at 8:10 am
    [John Rofrano] “That’s really strange because I rendered some HD footage with the Morgan MJPEG codec trial and it looked great. No jagged edges or anything. I was using the 64-bit version of the Morgan codec.”
    In which format did you rendered that footage? The thing that shocked me most is that no matter what preset I used in Vegas and Premiere, the result was the same. And no matter what player and filter I used, the picture was jagged. But in the timeline and preview window it looked great.
    I’ll try to post a screenshot during this morning if I can manage to connect to my home computer via Teamviewer so you can watch it. Maybe it will enlight us 🙂
    Edit to include link to img
Page 1 of 4
