Activity Forums Adobe After Effects color artifacts in 16bit image
  • color artifacts in 16bit image
    Posted by Jovan Strel on June 28, 2013 at 1:14 pm
    i having a problem with footage which is >
    If i increase the bpc of the composition from 8 to 16bit or 32, i get a lot of color artifacts in areas that are brightly lit, or where the highlights are strong
    in player (quicktime and vlc) everything is fine, but in after it keeps showing. I’ve also tried in Nuke, same problem
    I use AE CS6, the same problem happens in CS3
    its a video footage, 10 bit image, and was exported from avid in quicktime DNxHD
    any suggestions? thanks
    Jovan Strel replied 13 years, 3 months ago 2 Members · 2 Replies
  • Walter Soyka
    June 28, 2013 at 4:18 pm
    [Jovan Strel] “in after it keeps showing. I’ve also tried in Nuke, same problem… its a video footage, 10 bit image, and was exported from avid in quicktime DNxHD”
    I think this is a QuickTime issue. This might be better in CC, in which Adobe added native support for DNxHD.
    That said, here’s an ugly workaround: add a color limiter effect on the Avid before export:
    https://community.avid.com/forums/p/109346/633841.aspx#633841
    You might instead try using RGB instead of 709 encoding for the DNxHD output; I don’t know for sure that would work and don’t have suitable footage here at the moment to test, but since the problem is occurring in the superbrights, it could be worth a try.
    Walter Soyka
  • Jovan Strel
    June 28, 2013 at 5:08 pm
    thanks for help – the link confirmed what i was thinking, those supewhites, blaaast them 😀
    instead of exporting in quicktime, i will ask for dpx sequences – hope it fixes it
    thanks again
