Activity Forums Apple Motion Color and/or Gamma shift between photoshop and motion
  • Color and/or Gamma shift between photoshop and motion
    Posted by Ellen Osborne on May 21, 2014 at 4:43 pm
    HI
    My psd documents are very washed out when I import them into Motion. If I import the same doc into AE, the colors remain accurate. There must be a setting somewhere in Motion to make it read the color correctly from photoshop, but I can’t seem to find it.
    Color setting in photoshop is Colormatch RGB 8 bit. Using Motion 5. Photoshop CS6. Mac Pro. Mavericks.
    Thanks for the help.
    Gareth Randall replied 12 years, 3 months ago 3 Members · 3 Replies
  • Robin S. kurz
    May 21, 2014 at 6:01 pm
    I would suspect that it has layer effects, adjustment layers or the likes. Motion doesn’t do layer effects etc.
  • Ellen Osborne
    May 21, 2014 at 6:07 pm
    There are no layer effects or adjustment layers.
  • Gareth Randall
    May 27, 2014 at 6:00 am
    I can confirm that I’ve seen a gamma shift in the past after exporting stills from FCP7, working on them in PS (usually painting things out) and then reimporting them. But I’ve just tried a few experiments now, and I can’t replicate it!
