Activity Forums Adobe After Effects Expressions Color and Position
  • Color and Position
    Posted by Nikola Morin on November 15, 2012 at 2:38 pm
    Hi everyones
    how can i link a color to a position?
    What I want is:
    if my arrow layer is between for example 100 and 200 on the X axis i would like affect the colors of my red solid who’s having a Fill effect on.
    The color between 100 and 200 is blue.
    So how should I write my expression to tell to the color fill effect of my red solid to become blue when the arrow is between 100 and 200 on x axis???
    am i enough clear???
    Thank you!!!!
    Nikola Morin replied 13 years, 9 months ago 2 Members · 5 Replies
  • Dan Ebberts
    November 15, 2012 at 3:41 pm
    It will be something like this:
    arrow = thisComp.layer("arrow");
    p = arrow.transform.position;
    if (p[0] > 100 && p[0] < 200)
    [0,0,1,1]
    else
    value
    Color values are four-element arrays (RGBA) with values between 0 and 1, so solid blue would be [0,0,1,1].
    Dan
  • Nikola Morin
    November 15, 2012 at 3:55 pm
    How Come it becomes so simple when you explain this??
    Thank you again Dan that work perfectly!
    i knew about the four-element in the array, it was moe how to write this. when a tell it in my head it’s really simple, but it’s writting the langage who’s not simple!!
    Thank you and have a nice day!
  • Nikola Morin
    November 15, 2012 at 4:27 pm
    What happen if i have multiple condition?
    the expression was:
    arrow = thisComp.layer(“arrow”);
    [0,0,1,1]
    else
    value
    but if i have something between another color between 250 and 350 pixel on the x axis? ond still another color between 400 and 500
    How should write with multiple condition??
    Thank you!!
  • Dan Ebberts
    November 15, 2012 at 4:32 pm
    You could do it like this:
    [0,0,1,1]
    else if (p[0] > 250 && p[0] < 350)
    [0,1,0,1]
    else if (p[0] > 400 && p[0] < 500)
    [1,1,0,1]
    else
    value
    Dan
  • Nikola Morin
    November 15, 2012 at 4:35 pm
    thank you!!! work perfectly!!
