Activity › Forums › Apple Final Cut Pro Legacy › Color and Color Solid display different colors for same RGB values
  • Color and Color Solid display different colors for same RGB values
    Posted by James Skinner on March 17, 2011 at 4:51 pm
    As the title suggests if I plug an RGB value into the color or color solid matte generator they appear as totally different colors,
    doing the same for Rectangle provides a different shade of color still…very strange behaviour, does anyone know what’s up, or better still which is the right version to use (this is for a Pro Res HQ workflow).
    I can only assume it might be some kind of YUV /RGB issue, as I know that color solid is one of the fxplug generators from motion…otherwise I’m stumped…
    Any help would be much appreciated…
    James
    *EDIT* Sorry a bit more info this is on FCP 7.03…
    James Skinner replied 15 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
