Activity › Forums › AJA Video Systems › Color and Aja IO
Color and Aja IO
Posted by Baz Leffler on May 29, 2007 at 5:30 amIs there a trick to get the new FCS2 ‘Color’ to output to the Aja IO or is it a matter of waiting for the correct drivers?
What would I do without the ‘UNDO’ button!!!!
Michael Mcintyre replied 19 years, 3 months ago 4 Members · 5 Replies -
Russell Lasson
May 29, 2007 at 7:36 pmMy guess is that it should work with SD footage, but if you have HD footage, you’re probably out of luck.
-Russ
Michael Mcintyre
May 29, 2007 at 7:50 pmI’m keeping my fingers crossed as well. This was one of my bigger concerns {making sure Color would work w/ Aja IO}.
Different application but Shake does not ‘talk’ to my Aja IoLA and, last time I checked, there were no plans of updating drivers or anything because the new Final Cut was coming out (w/ Color obviously).
Can’t they all just get along? Pllleeeassseee…..
Baz Leffler
May 30, 2007 at 12:08 amWhen I go to the settings in Color and select the external monitor it shows all the Aja IO settings but they are greyed out and can’t be selected. Only a fool would colorgrade off a computer screen! (well at least for broadcast television)
Baz
Dave Garcia
May 30, 2007 at 4:50 amColor seems to be working pretty well with my Kona LH. Obviously, it’s not an IO, but I just thought I’d let y’all know.
Michael Mcintyre
May 30, 2007 at 8:11 amInteresting that you’d see the Aja options ‘inside’ Color and then have them grey’ed out.
You’d think they wouldn’t be there at all if it weren’t going to be an option {at some point}. Maybe driver update down-the-road? Maybe wishful thinking?
To be honest, none of my take-home projects are HD… yet. AND I need the 4 channels of audio from my IoLA. I’d love to hear that there is indeed going to be Io support for Color. I’d also love to hear that I won the lottery but 1 out of 2 ain’t bad.
