Activity Forums Adobe Premiere Pro Color Adjustment
  • Color Adjustment
    Posted by Joe Landau on July 5, 2005 at 6:01 pm
    I bought a Dell Inspiron 9300 laptop and am using it for video editing. The monitor colors seem rather cold compared to my 19″ CRT. I adjusted the colors using XP color adjustment capabilities, and managed to make the colors warmer as they appear in Photoshop. However, when I use Premiere, the colors look as if I hadn’t made any adjustment. Is there a way to make them warmer in Premiere?
    Craig Howard replied 21 years, 2 months ago 3 Members · 2 Replies
  • Aanarav Sareen
    July 5, 2005 at 6:19 pm
    [Joe Landau] “when I use Premiere, the colors look as if I hadn’t made any adjustment. Is there a way to make them warmer in Premiere?”
    Are you referring to the actual video or the color of the interface?
    PS: I have a 9300 as well. If you head over to notebookforums.com, someone posted a link on how to reasonably balance the LCD.
    Aanarav Sareen
    Adobe Certfied Expert, Premiere Pro
    https://www.asvideoproductions.com/video
  • Craig Howard
    July 5, 2005 at 9:52 pm
    My monitors run something called ‘Adobe gamma loader.exe’ if it helps.
    I believe it came from Adobe Photoshop but maybe it installed with PremierePro or even After Effects ( although I have only had this recently).It has been on my many NLE / Graphic machines (various over ten years) and I never recall installing it seaparately.
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
