Activity Forums Maxon Cinema 4D collision node, not working when dynamics included
  • collision node, not working when dynamics included
    Posted by Ronny Traufeller on September 16, 2015 at 11:47 pm
    i have some sort of pinball setup,
    where the ball touches objects inside.
    In Xpresso i use the collision node,
    with a selection, for each object.
    basicly it works, when i move the ball
    by hand. i can see the texture changing
    attached to the selection.
    but when using dynamics it is not
    happening.
    ( i tried the priority in expresso, but no success )
    maybe someone
    knows the solution.
    thanks,
    Ronny!
    also file:
    9261_pinball01cow.c4d.zip
    traufeller.de
    Ronny Traufeller replied 11 years ago 2 Members · 2 Replies
  • Brian Jones
    September 17, 2015 at 2:04 am
    I think you are going to have to use the Dynamics Collision Node instead – probably no collision is happening by the rules of the older collision deformer – harder to get the head around, far more powerful but it doesn’t output the collision as a selection tag..
  • Ronny Traufeller
    September 17, 2015 at 9:43 pm
    hey brian,
    perfect, i didnt know that
    there is another node for dynamic collisions,
    but it makes sense.
    i will find a way with that one.
    thankls a lot!
    Ronny
    traufeller.de
