Activity Forums Maxon Cinema 4D collision gravity and balloons
  • collision gravity and balloons
    Posted by Stuart Paciej on May 28, 2010 at 3:41 pm
    Hello all,
    I am going to be embarking on a project where I need balloons to rise and bump off each other, they will probably need to bounce in a kiddy style as well.
    I don’t know how I am going to do this though so a gentle nudge in the right direction would be appreciated!
    The criteria:
    Balloons must collide, and ideally be able to burst, the only way i know of doing this at present is to use clothilde?
    If I generate them as particles with gravity wind turbulence etc. will they collide? And will I be able to make them collide with another object which is not a particle?
    Would mograph 2’s solid body be of any use?
    Any help / tutorials on collision & particles would be greatly appreciated!
    Many thanks,
    Stu
    r11.5
    Randy Johnson replied 16 years, 3 months ago 2 Members · 1 Reply
  • Randy Johnson
    May 29, 2010 at 6:23 pm
    Here is a start file using Thinking Particles. I just set up a preset. https://rootvisuals.blogspot.com/2010/05/thinking-particles.html
    The pop is another step. Its just a matter of setting up a group change condition with a trigger. If this is what your looking for I can help you there too.
    If you go the cloth route…All the balloons have to be one object. I really like the bounce then since it has such nice contact. The TP contact is really linear… At least for me it is.
    /Randy
