Activity Forums Maxon Cinema 4D collision and rigid body
  • collision and rigid body
    Posted by Tom Dempsey on September 15, 2015 at 1:06 am
    Hi, a new user here with cinema 4d and have started using the rigid body tag for some basic dynamics.
    My question for the experts is this. I would like something along the lines of 2 helmets in a scene.
    have them stable, then collide with each other and bounce back into position. I’ve tried using
    keyframes with the force simulation to no avail. thanks in advance.
    td
    tom dempsey
    Tom Dempsey replied 11 years ago 3 Members · 3 Replies
  • Brian Jones
    September 15, 2015 at 3:08 am
    just like in reality where getting two objects to bounce off each other (if they were ‘stable’ how do they hit each other?) and then return to where they are might be possible but practically impossible you’ll have to cheat likely. More info is needed, what is happening? Why do the helmet hit each other? Are they still then move toward each other and you want the magical bounce back to the starting point?
  • Tormi Kadak
    September 16, 2015 at 9:41 am
    I hope I understand correctly.
    Maybe give them initial velocity?
    You can do this under the dynamics tab of rigid body, by checking “custom initial velocity” and setting a value
  • Tom Dempsey
    September 17, 2015 at 1:55 pm
    Thank you. i’ll try that.
    tom
    tom dempsey
