Activity Forums Adobe After Effects Collecting Files for only One Composition.
  • Collecting Files for only One Composition.
    Posted by Edward Vosper on June 29, 2015 at 9:00 am
    Hey Guys,
    This has been bugging me for some time and looking for an answer as I can’t seem to find one!
    When working on a Project with a lot of Compositions, I sometimes want to collect maybe 1 or 2 from the project I’m working on to take across to another project.
    They way is normal do this is using the Collect File… system in the File drop down menu.
    This always works for me, but! It brings along all of the comps and folder I have been working on, but all i really need is the 1 or 2 that i like.
    Is there away to export or collect a single comp with all the assets to a new project?
    Hope that made sense and someone out there has the answer!
    E
    http://www.edwardvosper.com
    Walter Soyka replied 8 years, 4 months ago 3 Members · 4 Replies
  • Walter Soyka
    June 29, 2015 at 2:50 pm
    Select the comp, then File > Dependencies > Reduce project. Ae will eliminate everything not needed for your selection.
    Of course, you may want to save a copy of your un-reduced project first, or increment and save immediately after reducing.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Edward Vosper
    June 29, 2015 at 3:15 pm
    Thank you bro!
    Big help.
  • Haseeb Khan
    April 10, 2018 at 7:37 am
    hi ,
    what if i have multipul compostions and i want only one com to collect and other to remove
    cause some time u make many com with precom and u dont want to select one by one
  • Walter Soyka
    April 10, 2018 at 2:13 pm
    [Haseeb khan] “what if i have multipul compostions and i want only one com to collect and other to remove cause some time u make many com with precom and u dont want to select one by one”
    Same deal. You select the one you want, then use File > Dependencies > Reduce Project. This will remove everything from the entire project that is not required to render the comp you had selected.
    Walter Soyka
