Activity Forums Adobe After Effects Expressions Collect files with Expressions
  • Collect files with Expressions
    Posted by Nicolas J russo on August 9, 2016 at 6:38 pm
    Hi, I just ended a project that was a cumulative of templates, so it ended up being a really messy project since the templates were use partially. I did a collect, reduce file, try the script SAVE COMP AS PROJECT… all of them have the same problem: they do not collect the files that are used in the project´s scripts but only the ones that were used as part of the composition. So when I open the new “reduced” project, a lot of things are offline and AE shows me hundreds of error windows like the one I attached
    Is there a way to get around this?
    Nicolas J russo replied 10 years ago 1 Member · 0 Replies
  • 0 Replies
