Activity › Forums › Adobe Premiere Pro › Collapsing video tracks
  • Collapsing video tracks
    Posted by Eric Merklein on September 11, 2015 at 4:57 pm
    Is there a way to ‘collapse’ 2 video tracks?
    I have video on trk 1 and a graphic that I made in title tool on trk. 2.
    The graphic (a white square) is to cover up a date and location. Problem is that when i apply a fade in or a fade out, the rate is unequal and I can see the date and location as the transition progresses.
    In Avid I just collapse – apply a transition and the rate is perfect – even for 6 tracks of video.
    Any suggestions ?
    E
    Many thanks.
    Eric Santiago replied 10 years, 8 months ago 3 Members · 4 Replies
  • Massimo Alberto croce
    September 11, 2015 at 5:40 pm
    Collapse in premiere is call nest. select those two clip and choose clip>nest.
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Eric Merklein
    September 11, 2015 at 5:47 pm
    Thank you Massimo! I have to get this done quickly and you reached me in time.
    I checked out your site with the map. The location where you live loos exactly like that land i live on when i was in southern California.
    Grazie ancora per l’aiuto.
    E
    Many thanks.
    September 12, 2015 at 12:42 pm
    Prego.
    But I live in Rome.
  • Eric Santiago
    January 27, 2016 at 1:11 pm
    nesting works but what if you really want just one track for XML export?
    with nesting XML export into REDCINE comes up with an empty file.
    if I were to nest, multi-cam then flatten, you lose the other tracks.
    is there an option similiar to FCPX Collapse into main track (Primary storyline)?
