Activity Forums Adobe After Effects collapse trnsformation and MASK
  • collapse trnsformation and MASK
    Posted by Jon Herron on March 7, 2006 at 5:12 am
    After I apply a mask then collapse transformation is all in the wrong spot, Why? is these a precomposing issue? …man collapse trans’ and 3d space in AE is a pain in the ass
    Jon Herron replied 20 years, 2 months ago 2 Members · 4 Replies
  • John Dickinson
    March 7, 2006 at 5:22 am
    Make sure the layers inside the precomp are also 3D. Also keep in mind that collapsing transformations switches the render order, what is usually Masks, Effects, Transform properties becomes Masks, Transform Properties, effects.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Jon Herron
    March 7, 2006 at 5:38 am
    It seems like everything is switched to 3D. It gets a little rough going when I have so many comps, and nested comps. Then I start second quessing and making everything 3d and collapsed etc. Would the render order change effect masks, since it is first anyways? Do you have any advice for a more efficient workflow?…specifically, I quess when working with 3d space.
    thank you so much for your help
    jon
    sorry, one more thing- transform properties are scale, rotation, position, etc right??
  • John Dickinson
    March 7, 2006 at 5:55 am
    Why are you collapsing the layer that you are applying the mask to? Maybe if you can tell us a little more about what it is you are trying to do…
    Transform properties are Position, Scale, Rotation, Opacity and Anchor Point
    John Dickinson
    Motionworks
  • Jon Herron
    March 7, 2006 at 6:16 am
    I think I got it figured out. IT GETTING late and I need bed. Thanks for you help. I was just wondering why precomped collapsed layers, effect the position of the mask.
    thanks again. F’ING awesome FOX classic piece by the way, really really top knotch, I dig. Nice color treatment, and type. Is that just one long pull back of 3d space layers? sorry to get of topic, delerium is setting in…haha
    jon
