Activity Forums Adobe After Effects Collapse transformed 3d layer doesn’t cast shadow if any effects applied
  • Collapse transformed 3d layer doesn’t cast shadow if any effects applied
    Posted by Zol Ganbold on May 12, 2015 at 11:33 am
    Hello everyone,
    if i apply any effects to the collapse transform checked 3d layer it loses the ability to cast shadow,
    does anyone know any workaround?
    Thank you
    Cassius Marques replied 11 years, 2 months ago 3 Members · 3 Replies
  • Todd Kopriva
    May 12, 2015 at 4:15 pm
    See this for a list of the things that break shadow casting and other 3D layer interactions:
    https://helpx.adobe.com/after-effects/using/3d-layers.html#3d_layer_interactions_render_order_and_collapsed_transformations
    After Effects product manager and curmudgeon
    After Effects team blog
  • Zol Ganbold
    June 26, 2015 at 11:24 am
    couldn’t find any helpful information out there, it says its impossible to cast shadow if you have applied any effect to 3d layers with collapsed transformation, what a helpless point!?
  • Cassius Marques
    June 29, 2015 at 1:59 pm
    duplicate your composition (in the project pannel). Change those layer’s cast shadow to “only”. Place this new comp bellow the one you want effects applied. Thats one way to cheat it.
    I usually link everything between those comps together via expressions so I don’t need to keep changing things twice when/if needed.
