Activity › Forums › Adobe After Effects › Collapse Transformations vs Interlaced output. – Bug ?
  • Collapse Transformations vs Interlaced output. – Bug ?
    Posted by Multipasser on January 21, 2011 at 5:13 am
    I have a scene which uses illustrator vectors in animation.
    I’ve turned collapstransformations on for the vector layers to keep them sharp/crisp when zooming.
    But when I render out the animation with fields it gets weird artifacts, like banding on the edges. When you import the rendered footage back into AE (with seperate upper fields) it looks like the vector art is still interlaced on the edges!
    This seems to be a bug, because my friend just told me today that he had weird edges when rendering interlaced and collapsetransform. Which at the time I thought was his fault! But now I’m thinking different. SD resolution has this artifact pretty bad, HD has it to but not so noticable.
    Anyone got the same problem? Or know a solution.
    Multipasser replied 15 years, 2 months ago 3 Members · 3 Replies
  • Joey Foreman
    January 21, 2011 at 4:06 pm
    Just to clear up some terminology. That button actually has two names. When it’s used on a vector layer it’s called Continuously Rasterize.
    https://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c1103906c6dea-7f49a.html
    Joey Foreman
    Editor/Compositor/VFX Artist
  • Kevin Camp
    January 21, 2011 at 6:26 pm
    ae doesn’t do a great job of deinterlacing, so on hard edges, you’ll almost always have some artifacts… but that doesn’t really matter, since ae is not the final destination, right?
    i assume that the render now goes to an nle, or a device that will playback in fields (dvd, tape, broadcast playout device)… that’s where you need to look at the render, and why dave asks if you are viewing the playback on a broadcast monitor, rather than a computer screen.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Multipasser
    July 27, 2011 at 4:35 pm
    No. I have this problem to. I had this problem few months ago and I’m having it now again!
    This is really a BUG!
    I have a blackmagic and LCD. I will have a check but it really doenst look good, even back in AE!
    Especially if you have a EPS that you scale up to 200%, put collapse transformations on, and render that out as a quicktime with fields, you will notice it immediately.
