Activity › Forums › Adobe After Effects › Collapse Transformation
Posted by Henrique Zuzz on October 23, 2014 at 1:02 amI Have work in project in After effects. I ´m using layers imported from Illustrator. I activate the collapse transformation, but anything happened. and the image continuous pixelated.
Thanks in advance for the help!
John Cuevas replied 11 years, 11 months ago 2 Members · 3 Replies -
John Cuevas
October 23, 2014 at 1:28 amIs it a vector image? If it is, post a screen grab of your timeline and composition.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Henrique Zuzz
October 23, 2014 at 3:39 amYes! It is a vector image! And even with the collapse transformations on, lines are pixelated. And any project with any vector image the same thing happens.
The image link.
https://images.creativecow.net/286563/image1.jpg
John Cuevas
October 23, 2014 at 1:53 pmYou are zooming into your image(800%). AE is showing you your comp, if you zoomed it that large. Go back to 100% size, select your AI layer, press “s” and then increase the scale to 800%, it will look fine.
Zooming in on your comp is fine–I do it all the time to properly align things, but everything will become aliased when you do that—just like it would if you did that with a picture or movie.
