Activity Forums Maxon Cinema 4D Collapse objects to 1 object?!?
  • Collapse objects to 1 object?!?
    Posted by Scott Wright on January 9, 2007 at 4:25 pm
    Hi there….. I’m sure this must be possible but at the moment am clueless how to do it.
    I basically want to collapse a grouped object similar how you would flatten layers in photoshop, when the object doesnt need to be edited any more, and to simplify it for renders I would like to just make it 1 item with materials on.
    In my example I have modelled 1 chip (for poker) then duplicated it several times, so to be able to flatten to make a stack but one object would be great.
    The actual example c4d file is at:
    https://www.dreamshock.com/chip.c4d
    Any help greatly appreciated!
    Scott
    Brian Jones replied 19 years, 8 months ago 3 Members · 3 Replies
  • Mylenium
    January 9, 2007 at 6:40 pm
    Select all your objectS/ items, then use Function –> Connect.
    Mylenium
    [Pour Myl
  • Scott Wright
    January 9, 2007 at 8:11 pm
    this kind of works, but it doesnt retain any materials, and also you have to convert all the object to editable objects too, I was hoping there may some easier way rather than having to expand all groups and subgroups?
  • Brian Jones
    January 9, 2007 at 9:16 pm
    Try ‘Current State to Object’ it also makes objects editable but it keeps textures and does the whole group automatically as it makes a duplicate.
