Activity Forums Adobe After Effects Collage effect
  • Collage effect
    Posted by Miriam Millan on October 7, 2005 at 3:51 pm
    Anyone out there know how to create a collage look, or know of any tutorials or articles on it. I want to build a collage effect with several pictures and backgrounds. The pictures need to be blended, not sharp edges, just as if it’s a collage.
    Thank you in advance.
    Miriam
    Miriam Millan replied 20 years, 11 months ago 3 Members · 3 Replies
  • Steve Roberts
    October 7, 2005 at 4:26 pm
    Import each photo, and drop each into your main collage composition. Draw a mask on each layer, cropping/masking each photo as desired. For each layer, hit MM to reveal the mask properties, and adjust the mask feather to taste. Scale and position each photo as desired.
    Steve
  • Tdsurf
    October 7, 2005 at 6:41 pm
    You could also then apply the ‘roughen edges’ effect and adjust to look like torn paper. Works great against the edge of a mask.
  • Miriam Millan
    October 8, 2005 at 5:19 pm
    Thank you for your advice. It helped a lot.
    Miriam
