Activity Forums Adobe Premiere Pro Collaborative Editing
  • Collaborative Editing
    Posted by Adi Kerr on October 14, 2013 at 5:46 pm
    Hi all, had a quick look and not sure I could find what I was looking for.
    Basically, got a shoot this week, after the shoot will dump all the footage onto an external drive and setup a PPro project.
    I then want to duplicate this drive to give to my friend who lives elsewhere so we both have the same files and file structure.
    My question is what is the best way to work together on this project? For example, can I open the project file, create an edit, send him the project file, he can work on it, send the project file back to me etc and everything will work OK? Or is there a better way to do it?
    FYI It’s a music promo, so there will be many multiple layers of video, not just a single track, and much of the footage will include speedbursts and reverse effects. There will be no other effects applied at this stage.
    Also I realise that Preview files will need to be generated by each of us, but I don’t see this as a problem, our machines are upto it.
    Look forward to your replies,
    Cheers
    *Edited to correct spelling
    Adi Kerr replied 12 years, 10 months ago 5 Members · 5 Replies
  • Alex Gerulaitis
    October 14, 2013 at 8:38 pm
    [Adi Kerr] “My question is what is the best way to work together on this project? For example, can I open the project file, create an edit, send him the project file, he can work on it, send the project file back to me etc and everything will work OK?”
    If the file paths (to source files primarily) are the same – yes. Someone did a detailed review on how to make a Premiere Pro project more portable (for working on it on a different system) – but I am blanking out who did it and where. (Todd? Dennis? Dave? Walter S.? Tim? Ann? Alex U.? Walter B.? Angelo? Could you guys help me out? :))
    [Adi Kerr] “Or is there a better way to do it?”
    Any service with two-way syncing should make it easier. GDrive does it for sure, DropBox I am sure does it too. I know how to set it up in G-Drive but it could be kind of cumbersome: designate a folder as a “Google Drive Folder” (say, “Premiere Pro projects”, and in Preferences (or “advanced settings”), tell it to only sync “some folder” to this computer, namely the folder with the project you’re working on. If you have a lot of other projects and files in that folder, this may require to move the project into its own separate folder, and set Pr preferences not to put previews and caches into it.
    — Alex Gerulaitis | Systems Engineer | DV411 – Los Angeles, CA
  • Michael Krupnick
    October 15, 2013 at 8:04 am
    For linking seamlessly, set all caches and drives to a folder ON THE MEDIA DRIVE in project prefs Use the system drive as backup for the project. Then you can exchange the minimum amount of data to maximum use. Works very well for any sharing enterprise.
  • Alex Udell
    October 15, 2013 at 6:05 pm
    Hi…
    seemed like most of the headaches involved had to do with working between mac and PC and resolving paths when media is stored in a complex folder setup at the OS level. (involving / vs and other petty annoyances)
    Walter Soyka had some goods things to say about this….
    If you are going to be working on the same project….and basing that on importing eachothers work into each others local projects…one REALLY BIG hint is…
    Import the SEQUENCES you need from the other project and not the PROJECT FILE itself…
    By importing the SEQUENCES, PPro will attach the sequence to your existing clip entries. if you import the project, PPro will create duplicate Clip entries in the project panel and things can bloat and get messy quickly.
    to prevent the email shuffle….Using AE…I’ve played with making my project folder a DROP BOX location and thus every time I save, being in sync with the drop box and on theory another editing location……..I suppose if you are only doing the project files this would work….but you’d been a pretty big drop box account to handle the media files…don’t think it’s impossible though…..but again….my experiments were only cursory…so don’t take it as gospel…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Walter Soyka
    October 16, 2013 at 2:18 pm
    You’ve gotten some great advice from the other posters.
    I’ll add that Premiere stores writes some metadata into supported media files directly when possible, instead of in the project file. That means that markers are saved in the footage and wouldn’t normally translate in your proposed workflow.
    I’d suggest you turn off “Write XMP ID to Files on import” in Preferences > Media, and I’d suggest you make all your footage locked (Mac OS) or read-only (Windows) before importing it to Premiere. That should force Premiere to save metadata in the project file, so you won’t have to continually exchange media files to keep markers up-to-date.
    Ideally, you’ll keep at least the relative path to media from the project file the same; even better if you keep the absolute paths the same.
    Walter Soyka
  • Adi Kerr
    October 16, 2013 at 2:21 pm
    Excellent responses, thanks for all of your help guys.
