Activity Forums Maxon Cinema 4D COFFEE script modification for 3 sided polygons (or failing that a quick way to delete all triangular polygons at once)
  • COFFEE script modification for 3 sided polygons (or failing that a quick way to delete all triangular polygons at once)
    Posted by Stuart Paciej on July 1, 2016 at 11:23 am
    Hello folk who are smarter than I.
    I am using Douwe’s d_Polysize effector to populate a mograph cloner onto a complicated (but flat) plane – the face of the plane is set to regular grid quads. But at the borders there are triangles.
    Its working really well for the quads, however as all the border triangles are different sizes its screwing the calculations there and creating undesireable results.
    So what I want to achieve is to tell the script if it finds a 3 sided polygon, then it should kill this clone or set it’s size to 0.
    Thanks in advance!
    Below is the script:
    map(input, inMin, inMax, outMin, outMax)
    var inrange;
    if((inMax-inMin) != 0) { inrange = (input-inMin)/(inMax-inMin); }
    else inrange = 0;
    return inrange * (outMax-outMin) + outMin;
    main(doc,op)
    var md = GeGetMoData(op);
    if (!md) return false;
    var cnt = md->GetCount();
    var marr = md->GetArray(MODATA_MATRIX);
    var fall = md->GetFalloffs();
    var cloner = md->GetGenerator();
    var obj = cloner#MG_OBJECT_LINK;
    var polycount = obj -> GetPolygonCount();
    var poly = obj -> GetPolygons();
    var points = obj -> GetPoints();
    var ud_scale_factor = op#ID_USERDATA:1;
    var ud_min_scale = op#ID_USERDATA:2;
    var ud_max_scale = op#ID_USERDATA:3;
    var i, scale, map_surface;
    var hi_pol_size = 0;
    var lo_pol_size = 9999999999999999999999999999;
    var part_1,part_2,a,b,c,d,e,f,s;
    var area = new(array,100000);
    var arr_A = new(array,100000);
    var arr_B = new(array,100000);
    var arr_C = new(array,100000);
    var arr_D = new(array,100000);
    for (i = 0; i < (polycount*4); i++) {
    if (i % 4 == 0) arr_A[i/4] = points[poly[i]];
    if (i % 4 == 1) arr_B[i/4] = points[poly[i]];
    if (i % 4 == 2) arr_C[i/4] = points[poly[i]];
    if (i % 4 == 3) arr_D[i/4] = points[poly[i]];
    for (i = 0; i < polycount; i++) {
    a = vlen(arr_A[i] – arr_B[i]);
    b = vlen(arr_B[i] – arr_C[i]);
    c = vlen(arr_A[i] – arr_C[i]);
    s = (a+b+c)/2;
    part_1 = sqrt (s*(s-a)*(s-b)*(s-c));
    d = vlen(arr_A[i] – arr_C[i]);
    e = vlen(arr_A[i] – arr_D[i]);
    f = vlen(arr_D[i] – arr_C[i]);
    s = (d+e+f)/2;
    part_2 = sqrt (s*(s-d)*(s-e)*(s-f));
    area[i] = part_1 + part_2;
    if (area[i]< lo_pol_size){ lo_pol_size = area[i]; }
    if (area[i]> hi_pol_size){ hi_pol_size = area[i]; }
    for (i = cnt – 1; i >= 0; –i)
    if (!area[i]){ area[i]= lo_pol_size; } // line for yader. in surface mode if clones > polys
    map_surface = map(area[i], lo_pol_size, hi_pol_size, ud_min_scale, ud_max_scale);
    scale = map_surface * (ud_scale_factor) ;
    marr[i]->SetV1(marr[i]->GetV1()*scale);
    marr[i]->SetV2(marr[i]->GetV2()*scale);
    marr[i]->SetV3(marr[i]->GetV3()*scale);
    md->SetArray(MODATA_MATRIX, marr, true);
    return true;
    Brian Jones replied 10 years, 1 month ago 2 Members · 1 Reply
  • Brian Jones
    July 1, 2016 at 9:51 pm
    the quick way to delete all triangular polys at once is to use the Structure manager – in the Attribute Manager choose Mode/Project Info and the Structure Manager is the third tab. If you have a poly object and you are in poly mode it will have buttons to select/deselect tri’s, quad’s etc…
