Activity Forums Adobe Premiere Pro Codecs in PPro 1.5
  • Codecs in PPro 1.5
    Posted by Steve Connor on April 20, 2005 at 3:36 pm
    Can PPro use codecs that are installed in the System 32 folder or do they have to be installed in Premiere’s codec folder? We are having problems gettin Premiere to recognise some avi’s that have a bespoke Mpeg 4 codec. It all worked in Premiere 6.5
    Steve Connor
    Cardinal HD
    Tim Kurkoski replied 21 years, 4 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    April 20, 2005 at 4:06 pm
    If it’s going to work at all, the codec needs to be installed so Windows can recognize it. Putting the codec files into the Premiere folder won’t do anything for you.
    What problems are you encountering specifically? Premiere Pro operates quite differently from the previous versions, and it’s possible that this codec may no longer be compatible. But there may still be a solution. Please provide more detail on what is happening. The exact steps you are taking and any error messages that occur will be helpful.
