  • Posted by Dan Davis on August 9, 2007 at 9:40 pm
    Hi.
    I am very very new to FCP6 coming from an Avid Symphony background.
    Is there a complete list of codecs for every possible format I can have a look at somwhere?
    Also I am running FCP on a Macbook Pro at the moment. SD and HD seem to run very well
    with no dropped frames using the ProRes codecs.
    This I know maybe a silly question but can I not just use this codec for everything I take in?
    One last thing. When dragging a upper field (odd) source to the timeline and then adding
    a lower field (even) source to the timeline how does the sequence react. Will the digi footage
    run smooth while the dv footage jitters?
    I am very sorry in advance if this sounds all to simple.
    Thanks for any help.
    Dan Davis replied 19 years, 1 month ago 3 Members · 3 Replies
  • Chris Borjis
    August 9, 2007 at 10:32 pm
    [Daniel26] “Also I am running FCP on a Macbook Pro at the moment. SD and HD seem to run very well
    This I know maybe a silly question but can I not just use this codec for everything I take in?”
    Absolutely. I do this as well.
    but beware that anyone you share files with has to have fcs 2 installed
    to get the prores codec for playability.
    You get even more codecs if you install kona or black magic cards.
  • Rafael Amador
    August 10, 2007 at 3:15 am
    The most compleat information about QT codecs you can find it here:
    https://codecs.onerivermedia.com/
    [Daniel26] “One last thing. When dragging a upper field (odd) source to the timeline and then adding
    run smooth while the dv footage jitters?”
    If your sequence is Upper-first, the digi footage will run smooth and your DV footage crap,
    If the sequence is Lower-first. will be the opposite.
    BTW, Borgis, did you had a look to the Sheer web-site? I would like to compare it with ProRes but I’m still in 5.1.2
    Cheers,
    rafael
  • Dan Davis
    August 10, 2007 at 6:10 am
    Thank you very much.
