  • Posted by Gracias on June 18, 2005 at 6:01 am
    Hello,
    I work on G5 2.5 GB Ram, Dual 2.5, Running FCP 4.5HD.
    Just keen to know what r the capturing setting which has respective codecs. I feel the suspect for which I get jittering during speed change.
    Is it DV 48Khz is apple codec, and Targa cine Wave YUV is Cinewave codec, Cud any one please help to sort this confusion. So If I want to captue SDI then what?
    Regars
    Gracias
    Gracias replied 21 years, 2 months ago 2 Members · 4 Replies
  • Walter Biscardi
    June 18, 2005 at 10:49 am
    [Gracias] “Just keen to know what r the capturing setting which has respective codecs.”
    All capture settings have codecs. Which codec are you looking for?
    [Gracias] “Is it DV 48Khz is apple codec, and Targa cine Wave YUV is Cinewave codec, Cud any one please help to sort this confusion. So If I want to captue SDI then what?”
    Apple has multiple codecs in Final Cut Pro. Third party hardware manufacturers generally add their own as well. To capture SDI, you need a hardware board with an SDI I/O. You then set FCP to capture using that hardware.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Gracias
    June 19, 2005 at 6:41 am
    Hello,
    Thankx for the reply.
    I looking for Cinewave Codec for Cinewave. As I am using Cinewave card on my MAcG5
    So ih my Easy Set up and in Audio Video Setting what it has to be in order to get everything Cinewave codecs.
    Regard
    Gracias
  • Walter Biscardi
    June 19, 2005 at 10:28 am
    Anything that starts “Targa” in the Easy Setups or Sequence Settings or Captur Settings is a CineWave codec. Such as something like “Targa YUV 8bit NTSC” or something like that. It’s been over a year since I last ran my CineWave system.
  • Gracias
    June 20, 2005 at 5:16 am
    Hello,
    So shall I assume Whatever is there in the Bracketi.e. Targa YUV (8bit) Balance Pro analogue along with the Targa is also Cinewave codec. Otherwise rest is Apple Codec.
    Actualy one of my support engineer told me so.
    Please confirm. Thankx for u r response
    Regards
    Gracias
